Lees de OBD-II uit met je iPhone
Sander
Forum Admin
Bericht door Sander » ma 29 sep, 2008 10:28
Na al eerder dit leuke iPhone programma gevonden te hebben waarmee je vrij accuraat het vermogen van je Saab mee schijnt te kunnen bepalen vond ik vandaag dit programma: Rev (lite).
Here's another iPhone application that demonstrates that soon there is nothing you won't be able to know if you have just one device. DevToaster has created an app called Rev that reads information straight from the OBD-II port on your car and displays it on your iPhone. When it's fully operational, Rev can display things like vehicle speed, RPM, fuel consumption, calculated engine load, and a host of other parameters. You'll even be able to check and reset engine and error codes.
The only hitch is that you need an OBD-II/WLAN interface that can beam the information from the port to the phone. DevToaster is working on that now; in the meantime, you can download Rev Lite at their site.
AfbeeldingAfbeeldingAfbeelding
Rev Features
Built-in Metrics (No special hardware required)
* Lateral and Forward Acceleration: Graph your cornering, braking and acceleration G-forces. (Available in Rev Lite)
* GPS Track: Visual track displays your location and acceleration data - see how you are braking and accelerating around corners. (Available in Rev Lite)
OBD Metrics (Requires OBD-II/WLAN interface hardware)
* Vehicle Speed
* RPM
* Fuel Consumption
* Engine Coolant Temp
* Fuel Pressure
* Calculated Engine Load
* Throttle Position
* Intake Manifold Pressure
* Air Intake Temp
* Timing Advance
* Mass Air Flow
* Fuel Level
* Barometric Pressure
* EVAP System Vapor Pressure
* Fuel Trim
Visual Representations
* Gauge: Displays a moving needle and LED display to show current reading
* Graph: Displays current value over time
Engine Code Retrieve and Reset
Want to know why your Check Engine light is on? Rev will tell you why!
* Engine code checking
* Listing of all engine codes thrown by the vehicle
* One-button reset of your codes and Check Engine light
Auto-centric User Experience
Rev has been designed to be easy to use in car-mounted iPhone/iPod Touch installations.
While we OFFICIALLY DO NOT RECOMMEND USING Rev OR OTHER IPHONE/IPOD TOUCH APPLICATIONS WHILE DRIVING, we do think it would be a mind-bendingly awesome experience were anyone to actually try it.
* Quick taps for bumpy rides - double tap gauge to zoom in/out, swipe to graph view
* Car-mount-friendly orientations - landscape or portrait
* Dark background color scheme - easy on the eyes, day and night
Wireless Freedom
Simply connect to the OBD-II/WLAN device by approaching your car. While connected, your iPhone can still access the Internet via EDGE or 3G.
Het ziet er veel belovend uit!
**weet iemand of een OBD-II/WLAN-interface te koop is voor een Saab?**
Nu nog gratis te krijgen met iTunes. Ik vermoed dat de betaalversie waarschijnlijk max 10,- zal gaan kosten.
Zie de website van Rev: http://devtoaster.com/products/rev/index.html
Sander
(jammer jammer jammer dat ik met mijn 900NG uit 1994 nog geen OBD-II kan aansluiten :( )
Coenwagner
Re: Lees de OBD-II uit met je iPhone
Bericht door Coenwagner » ma 29 sep, 2008 10:42
Is turbodruk :wink:
Sander
Forum Admin
Bericht door Sander » ma 29 sep, 2008 10:45
Kijk dat is mooi :)
inactief
Bericht door inactief » ma 29 sep, 2008 12:42
Vet!
Ik heb meteen maar ff (alvast) het programmatje gedownload op m'n telefoon. Jammer dat dat niet gewoon met zo'n blauwtand ding kan, zo'n kastje heb ik al liggen...
gr Gijs
900 SE C
Bericht door 900 SE C » do 19 nov, 2009 22:51
Berry schreef:Morgen krijg ik een iPhone 3G dus ik kan het binnenkort uitproberen!
en.. en.. en?
inactief
Bericht door inactief » do 19 nov, 2009 22:54
Je moet een wifi OBD-II kastje kopen voor meer dan 100 euro. Beetje veel geld als je al zo'n kastje (blauwtand) voor de laptop hebt slingeren...
AlexJ
Bericht door AlexJ » vr 20 nov, 2009 11:55
hmmm, wifi.... :?
ik heb dus de usb versie...
bestaan er verloopdingen om usb apparaten op je iphone aan te sluiten?
ik hoop het, want dan zou dit programma misschien nog wel eens gaan werken voor mij :P
inactief
Bericht door inactief » vr 20 nov, 2009 13:07
Nope, only wifi...
AlexJ
Bericht door AlexJ » vr 20 nov, 2009 15:11
G-ice schreef:Nope, only wifi...
Ja, maar heel moeilijk zal het niet zijn om gegevens ipv naar wifi, naar de output van de iphone te zetten toch? Dat was meer wat ik bedoelde.
Bezemwagen
Bericht door Bezemwagen » wo 16 dec, 2009 18:14
Zo, weer even naar boven in de rij.
Heeft iemand toevallig al zo'n wifi apparaatje gevonden tegen een goede prijs? Ik heb gezocht maar nog niet gevonden.
Groet,
Martin
Sander
Forum Admin
Bericht door Sander » wo 16 dec, 2009 18:21
Wat vindt jij een goede prijs?
Ik weet een plek waar ze 100,- kosten
inactief
Bericht door inactief » wo 16 dec, 2009 18:38
Meteen als ie beschikbaar is (app wacht nog op goedkeuring Apple) gaat dit in mijn Saabrio:
http://www.innovatemotorsports.com/products/ot2.php
Tot op heden de leukste / mooiste / beste oplossing die ik gezien heb!
:jumper4: :jumper3: :jumper4: :jumper3: :jumper4: :jumper3: :jumper4: :jumper2: :jumper4: :jumper3: :jumper4: :jumper3:
Hanm
Bericht door Hanm » wo 16 dec, 2009 18:58
Yeeehaaa, dat ziet er goed uit, hebbe, hebbe, hebbe :P
Sander
Forum Admin
Bericht door Sander » wo 16 dec, 2009 19:27
Ziet er inderdaad goed uit. Heel vergelijkbaar met andere oplossingen.
inactief
Bericht door inactief » wo 16 dec, 2009 19:37
Sander schreef:Heel vergelijkbaar met andere oplossingen.
Ik wil deze juist omdat hij niet vergelijkbaar is met andere oplossingen. Wanneer je nog een paar euro's meer uittrekt klik je er bijvoorbeeld je innovate breedband lambda aan, en met nog wat extra euro's hangt ook je EGT (uitlaatgas temperatuur sensor) aan de iPhone.
Tevens lees ik dat je kunt loggen met logworks én die logs kan oplaan!
Vette shit dus, weg met die laptop op de bijrijdersstoel, weg met die in de kabelboom gehackte can/usb interface!
Ik ben zeer benieuwd heb naast wat twijfels over de te loggen parameters toch goede hoop dat dit is wat ik wil!
