[CH] Fraaie 900S Aero, 1993, 279.000 km., 2e eig.
Bericht door gj900 » wo 24 apr, 2024 20:06
Mooie kleurcombi, alleen dat chroom stoort in mijn ogen :shock:
https://www.hemisphere-garage.com/1993- ... v-aero-red
SAAB 900 S TURBO 2.0L 16V AERO
17’000 CHF
ENGINE
all new service parts and fluids
new do88 silicone air hoses all around
new crankshaft oil seal clutch side
new bushing alternator and steering pump
new turbo bypass valve
ENGINE PERFORMANCE
Slightly improved with APC valve and original intercooler around 190hp
EXHAUST SYSTEM
Custom made exhaust system with original catalyst
new bushings
GEARBOX & DRIVE TRAIN
5-speed manual gearbox shifting very good
new gearbox oil
new clutch kit, master & slave cylinder, clutch line, pilot & release bearing
resurfaced flywheel
new clutch axle seal
new front left and right cv axles
STEERING REFURBISHMENT
new steering column axle bearing and bushing
CHASSIS
new shock absorbers
laser alignment
BRAKE SYSTEM
restored brake calipers front and back
new ABS sensors
SHINY WHEELS
Super aero 16’’ rims with good summer tires
EXTERIOR
Whale tail
Aero body kit
new fuel neck filler
INTERIOR
very good condition beige leather seats
original 3 spoke SAAB steering wheel
SRS/airbag delete
new column bearing and bushing
very good headliner
key copies
new interior heating radiator and valve
Add on options at extra cost such as:
other rims
and more…
Get in touch with us for possibilities and prices.
THE CAR COMES WITH SERVICE DOCUMENTS AND INVOICES + OWNERS HISTORY
HERE ARE SOME WORK DONE AT 250’000KM
new cylinder head, valve cover, exhaust+intake manifold gasket
new front and back crankshaft, oil pump seal
revised distributor
new water pump, thermostat, radiator
and more..
Re: [CH] Fraaie 900T16 Aero, 1993, 279.000 km., 2e eig.
Bericht door Saapie » wo 24 apr, 2024 20:31
Daar is ie weer. Stond enige jaren ook te koop. Jammer dat ie van die chromen raamlijsten heeft.
Bericht door Sonab » wo 24 apr, 2024 23:01
Ik vind de auto zo gek uitkomen op de foto's, alsof hij er onder een foute hoek ingeplakt is. Ligt dat nou aan mij? :-S+
Bericht door Saapie » wo 24 apr, 2024 23:22
Je hebt gelijk. Hij staat wat hoog op de banden, en is denk ik op een helling gefotografeerd
Bericht door gj900 » vr 26 apr, 2024 11:37
Betere foto's van deze beauty:
Re: [CH] Fraaie 900S Aero, 1993, 279.000 km., 2e eig.
Bericht door gj900 » wo 08 mei, 2024 21:37
Filmpje erbij:
ljdekker
Bericht door ljdekker » wo 08 mei, 2024 22:48
Die raamlIjsten maken hem heel oud
Bericht door gj900 » do 09 mei, 2024 11:59
Klopt, staat heel vreemd op deze 900. Gelukkig is dat te veranderen.
Bericht door Saapie » do 09 mei, 2024 14:35
Jaren geleden heb ik naar deze auto geïnformeerd. Stond toen te koop voor net onder de 10.000 euro. De eigenaar heeft wat smaakgevoelige dingen veranderd. Maar de basis is goed. En een waanzinnig mooi interieur. Zelf zou ik 190 pk met standaard IC een beetje tricky vinden, en een DO88 IC hebben gemonteerd
