massapunten met foto's
Geplaatst: za 22 sep, 2012 9:38
door Rhinobirds
Het heeft mij zelf een tijdje gekost om alle massapunten te vinden, daarom hier een overzichtje met foto's. Ik heb nog niet van alle massapunten foto's maar probeer het binnenkort wel compleet te maken. Uitgangspunt is dit overzicht maar dat kan niemand echt goed lezen zonder flink in te zoomen. Van links naar rechts en boven naar beneden:
G100 (on left front structural member) :
left high beam headlight, left low beam headlight, left front parking light, left front turn light, radiator fan motor, horns, left headlight wiper motor, left front fog light, left side backup light, light reduction relay, a/c radiator fan, theft alarm hood switch, left front side marker light, front lamps filament monitor, boost pressure control valve, secondary air injection pump motor, radiator fan a/c cut-out relay
G101 (on right front structural member):
right high beam headlight, right low beam headlight, right front parking light, left front turn light, washer fluid pump motor, right headlight wiper motor, right front fog light, right side backup light, 3-stage a/c pressure monitor, washer fluid level monitor, right front side marker light, coolant level monitor, a/c high pressure monitor
G301 (on right front seat member):
passenger's seat heating pad, passenger's side seat belt switch, right rear door ajar switch, right rear fan motor, passenger's seat heating pad switch, passenger's seat temperature sensor, audio system amplifier, passenger's power seat switch, selector lever microswitch, passenger's power seat relay
G112 (on left side engine bracket):
mass air flow sensor, oxygen sensor preheater, ignition discharge module, trionic engine control module, trionic data link connector, motronic engine control module
G300 (on left front seat member):
driver's seat heating pad, driver's seat belt switch, a/t selector position switch, driver's heating pad switch, driver's seat temperature sensor, driver's seat memory control module, power windows/sunroof switch, driver's power seat relay (97)
G304 (below left rear seat):
license plate light, high level brake light, rear window wiper motor, luggage compartment light switch, tailgate motor, left rear door ajar switch, rear lamps filament monitor, left rear fan motor, fuel pump, backup light assembly, tcs control module (V6)
G116 (left side of safety wall):
abs electronic control module, abs main relay
G404 (left hand luggage compartment):
left rear park light, left rear turn light, left brake light
G403 (right rear wheel well):
right rear park light, right rear turn light, right brake light, backup lights
G302 (below front of center console):
srs control module
G402 (left rear wheel well):
power antenna
G406 (5 door)(on tailgate):
rear window heating element
G201 (on left side of dashboard electrical distribution box):
glove compartment lamp, ignition switch relay, turn signal relay, hazard flasher switch, seat belt/ighnition key warning relay, intermittent windshield wiper relay, rear intermittent wiper relay, rear defogger time delay, rear defogger switch, power mirror, recirculation switch, interior lighting time delay relay, heater controls lighting, a/c switch, daytime driving lights relay, passegner's door ajar switch, driver's door ajar switch, anti-theft alarm control module, baclup lights relay, driver's door microswitch, passenger's door microswitch, shift lock relay, data link connector, starter interlock relay, rear fog light relay
G102 (left front shock tower):
abs diode, abs hydraulic pump motor
G202 (on left facia reinforcing member):
light switch, lighting control rheostat, ignition switch, horn switch, fuel level gauge, fuel reserve indicator lamp, coolant temperature gauge, high beam indicator, turn indicators, rear defogger indicator, rear fog light indicator, cruise indicator, lights-on indicator, cigarette lighter, clock, interior lights switch, front fog light switch, tachometer, power mirror switch, ashtray lamp, rear fog light switch, central locking system control module, left power mirror heating element, driver's door ajar switch, edu trip computer, high/low beam dip switch, acc control module, acc extractor fan, rear reading lamps, front reading lamp, driver & passenger seat heating switchers, radio, theft alarm led, steering wheel contact unit, audio system amplifier, make-up mirror lights, prewired telephone installation, data link connector, tcs off switch
G128 (on gearbox)
G102 (battery tray ground, on left front wheel well):
ventilation fan motor, brake fluid level warning switch, windshield wiper motor, acc controls, engine oil level switch, theft alarm siren, cruise control module, negative distribution terminal
Tot slot zitten er op het blok nog een drietal massapunten, 2 op het inlaatspruitstuk:
en 1 van de kop over de bovenste motorsteun naar de carroserie:
en de behuizing van de ECU zit zelf ook nog aan massa:
Re: massapunten met foto's
Geplaatst: za 22 sep, 2012 10:02
door everlast
duidelijke reportage :bluethumb:
Geplaatst: za 22 sep, 2012 10:51
door 9000-95
Handig!
Voor wie de overige ook nog wil vinden dit overzicht plaatje:
En omdat hier een andere nummering is aangehouden dan in bovenstaand verhaal de index erbij:
Geplaatst: za 22 sep, 2012 21:29
door Rhinobirds
dat is ook een goede!
ik heb ondertussen een paar foto's toegevoegd
Geplaatst: zo 23 sep, 2012 11:56
door nastydrive
Is het geen idee om dit modellen topic naar het 9000 handleidingen topic te verplaatsen
